1st Track Day Newbie Question
Discussion in 'General 1000RR Discussion' started by Snowcat, May 8, 2013.
  1. Snowcat
    Snowcat Active Member
    Just had the joining instructions for my upcoming track day which has got me a little excited and just wanted a little help/pointing in the right direction. I have to have my lights off and they suggest the simple method (switching off), unplugging the bulbs or taping them up. I can't switch them off and figured the easiest thing would be to pull the fuse or is there a particular reason that I shouldn't? I'd have thought that's safer than having loose wires flapping about and just pop the fuse back before I ride home.
  2. Slick
    Slick Elite Member
    On 08+ I think the light fuse is shared with the ignition -I could be wrong
  3. Barstewardsquad
    On my RR7 I just disconnected the cable and then used some garden cable twist to secure it to the strut between the yoke and the dash. Kept it out the way and was simple to put back on afterwards.
  4. And7rp2
    And7rp2 Elite Member
    Just gaffer tape them up !
  5. Tom68
    Tom68 Active Member
    I'd pull the conector off the back of the bulb. What track you at mate, I'm at Oulton on the 17th.
  6. Snowcat
    Cadwell on the 14th pal
  7. tgosai
    tgosai Member
    are you doing a novice session ?
    if so, then you shouldn't have to do much more than turn in your mirrors to be able to go on track. but saying that, I've never been to cadwell so not 100% sure on their policy, but most don't ask for all that. might be worth checking with the organisers
  8. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    I've just done cadwell and I am fuckin WEEELLLL JELOUS!!! Have an awesome time matey
  9. robinh73
    robinh73 Well-Known Member
    Just tape the headlights up and fold the mirrors in. Cover your speedo up too, last thing you want to do is look at it.
  10. Yorkshire Tyke
    When I went i taped up headlight, folded mirros (but in the end put back in road position and taped up cos they were annoying me) and taped up plate and rear tailight didnt have any problems, just remember to take it all off again if you go back on the road to fill up, like i didn't :)
  11. RichC
    RichC Active Member
    Aslong as you are not riding on full beam they will accept the daytime running light! Never bothered me in four visits.
  12. Repsol_Dan
    Repsol_Dan Active Member
    ive also got my first one at RAF Waddington this Saturday, this has been a great help, ill go buy some gaffer tape
