2 year Brake Fluid service
Discussion in 'Maintenance' started by Steve69, Jun 7, 2020.
  1. Steve69
    Steve69 New Member
    Hi Folks, I have a 2019 Blade and I'm just wondering if any of you have had the 2 year brake fluid replacement service done by a dealer? Need to know how much the mortgage application needs to be for
  2. Boothman
    Boothman Elite Member
    That depends on if it has ABS or not. No ABS is just a standard shafting if it’s an ABS it’s one hell of a shafting.
    EDIT - My bad, didn’t notice the year sorry. The pre 2017 took hours to sort even after Honda developed a ‘faster method‘
    #2 Boothman, Jun 7, 2020
  3. Ian E
    Ian E Active Member
    It should be relatively cheap - from what I understand it's just a conventional bleed on 2017 onwards (Bosch System)
  4. Steve69
    Steve69 New Member
    Yeah its abs so I'm expecting a good seeing to lol!
  5. Steve69
    Steve69 New Member
    Ah cheers , I've heard a few saying it's a bitch of a job even for main dealers so just wondered how much we might be talking g .
  6. Ian E
    Ian E Active Member
    They are all ABS 2017 onwards. It should be just part of a routine service if due, and a quick job. Bosch system is totally different to earlier Honda Combined ABS (Pre 2017)
  7. Ian E
    Ian E Active Member
    Just checked the Service manual - conventional bleed - a few minutes job
  8. Steve69
    Steve69 New Member
    Ahh that's good news then, yeah my last bike was a 2012 blade but non abs and I remember the dealer said that it was a 4 hour job! Glad they've got it sorted on the newer model , thanks for the info guys
  9. Steve69
    Steve69 New Member
    Cheers Ian , that's a big sigh of relief lol! I'll rip the remortgage application up now
  10. Arthur Yeo
    Arthur Yeo New Member
    It can be done by yourself in under 3 hours (for first timers) and more experience people, it's relatively straight forward & it should significantly less.
    Why not do it yourself? Grab the Service Manual, read that page and review a couple of YouTube and off you go.
  11. Steve69
    Steve69 New Member
    Ah thanks Arthur, i enjoy doing my own maintainence usually , i can do the straightforward stuff like swapping pads, oil & filter changes etc but heard nightmare stories about the brake fluid bleed but now i know its on the pre 17 blades I might give it a whirl. Took it for the 12 month dealer service last week at Padgetts in Batley, they did a good job and showed me everything they had done, even though there isn't that much to do on the second service at 3500 miles! £200.
  12. icedmind
    icedmind Active Member
    2017-19 blade is normal bleed; mine was done at the 16000mile big service all fluid changed with valve clearance plugs and filter at Southampton crescent Honda for 600quid ish; I had bleed the brake since then and if it’s just that then DIY it
