2006 Brembos ?
Discussion in 'General 1000RR Discussion' started by Spo, Apr 22, 2023.
  1. Spo
    Spo New Member
    Hi all
    Could anyone tell me which Honda brembo callipers will fit a 06 cbr 1000 rr? From 06 on they all look the same-ish ?
    thanks
    #1 Spo, Apr 22, 2023
  2. Muffking
    04 to 07 Blade are the same size and fitting, except the RR4/5 are a different colour to the RR6/7. It's only the discs that are different.
    There are probably some other Honda's of similar years that fit, but I wouldn't know which ones other than the fact that the VFR & CBR600RR of similar years used the same pads.
  3. Spo
    Spo New Member
    Did any of the 04-07 have brembo’s ?
  4. Muffking
    Well spotted. They were Tokiko. My bad.
  5. Spo
    Spo New Member
    Will brembos from a 08 + fit !? Discs seem to be the same size ? But I don’t know about hole pitch & off set ? ‍♂️
  6. Barstewardsquad
    Had M4s on my 07
  7. Spo
    Spo New Member
    Are they aftermarket or OEM ?
  8. raphael
    raphael Elite Member
    MP4’s won’t be oem on an 07, pretty sure of that mate
    • Agree Agree x 2
  9. Spo
    Spo New Member
    Would these fit ? There off a 09 rr !? 050A4690-1B05-4034-ADD3-15A7B9AABCAB.png
  10. Barstewardsquad
    Correct, replaced the OEMs with Brembo M4s. Bought them from some place in Italy IIRC
    If you see OEM ones advertised make sure they are the same spec. Pretty certain Suzuki did some M4 OEMs but they had smaller pistons in them.
    #10 Barstewardsquad, Apr 23, 2023
  11. ColinB
    ColinB Active Member
    Are all Brembo 108mm calipers the same offset? If so maybe here's a cheaper way of getting them Screenshot_20230424-130531.png
  12. Spo
    Spo New Member
    I’m not sure ? trying to find out mate ?
    #12 Spo, Apr 24, 2023
  13. warren smart
    warren smart Active Member
    I’ve got brembo M4’s fitted to my 08.
  14. kev.b
    kev.b Well-Known Member
    My 06 Blade Brembo m4 calipers, Brembo HPK T Drive discs , Ohlins forks with billet yokes.
  15. Spo
    Spo New Member
    Nice !£££££
