Also has anyone tried one of these-S-H10SO25-APLT/TD - Exhaust Muffler Akrapovic Track Day Honda CBR 1000RR ? I'm need to reduce noise level to go on Track ? tia
Rear Sprocket 63 Nm Front Sprocket 54 Nm Oil Filter 26 Nm Sump Bolt 30 Nm Fork Pinch Bolts 22 Nm Caliper Bolts 40 Nm Front Spindle 79 Nm Rear Axle 135 Nm Hope this helps buddy.
yes thanks jay, now trying for an hour put rear wheel on, why is it so fkn difficult? is there an easy way???
Not sure about the 20 model but the first time I tried putting the rear back on on my ‘14 it was a pain. In my case, Caliper bracket goes on the hub first, offer up the wheel, put the chain on the sprocket, push the axle in a little way, then as you push the wheel up and in, slide the caliper arm into the slot in the swingarm.
At first I unbolted the rear caliper off, made it way easier, then I got one of these kits, link below. Gilles AXB Chain Adjusters With Quick Change System - Gunmetal Grey | Gilles Controls | Chain Adjusters (calsport.co.uk)
