2107 quick shifter
Discussion in 'General 1000RR Discussion' started by chriso, Apr 23, 2018.
  1. chriso
    chriso Active Member
    Hi all
    Can you tell visually if a standard 2017 blade has had the quick shifter upgrade If so how
  2. nigelrb
    Hi Chriso.
    The best clue is a wire coming out of the gear lever linkage rod. Also the linkage rod will have a thick upper module (for electronics). Pics below illustrate:
  3. chriso
    Brilliant thanks for that
