50 / 55 tyres question
Discussion in 'General 1000RR Discussion' started by Nutty Tart, Oct 15, 2011.
  1. Nutty Tart
    Nutty Tart Well-Known Member
    So as the title says ... can any of you clever people out there tell me :-
    What is the percentage increase in the rolling radius when you fit the 55 tyre ?
    Its just that before fitting mine the speedo was really accurate . At a dyno 100 mph my speedo did read 102 . Now it could be under-reading as the tyre will travel more distance per revolution of the tyre .
  2. ColinBR
    I'd say the % increase is 10% for the tyre but quiite clearly it's only showing 2% on ur speed runs. Could b down to a lower tyre pressure on the 55 profile tyre?
    I'm only taking a guess though.
  3. Bikeracer1098
    Bikeracer1098 Active Member
    If your running a 190/50/17. The tyre height is 50% of 190mm=95mm, diameter of the wheel is 17"=431.5mm, diameter of wheel & tyre=431.5+190=621.5mm (each rotation is 1952.5mm)
    190/55/17. The tyre height is 55% of 190mm=104.5mm, diameter of the wheel is 17"=431.5mm, diameter of wheel & tyre=431.5+209=640.5mm (each wheel rotation is 2012.2mm)
    Therefore the inaccuracy will be 3%.
    If your speedo was previously reading 2% high, it will now be 1% low (with the 55 ratio tyres), i.e your speedo will be reading 99MPH when you are actually doing 100MPH.
    Try taking a GPS unit such as ROAD ANGEL etc out on the bike to compare.
    Hope that helps.
    #3 Bikeracer1098, Oct 15, 2011
  4. Nutty Tart
    Unfortunately I don't know anyone with a GPS to lend it to me .. but your maths looks sound and I do remember a previous post about rear sprocket in 44 and tyre size at 55 basically cancelling each other out . Or did I dream it .. ;)
  5. ColinBR
    OMG I now feel about the size of a pin head.
    Back to the ape cage for me :) lol
  6. Jamiestrada
    Here is the thread Nutty it was not a dream :)
    http://1000rr.co.uk/maintenance/1107-2.htm#post11404
  7. JM1
    JM1 Active Member
