87miles to full tank!
Discussion in 'General 1000RR Discussion' started by hump333, Feb 20, 2013.
  1. hump333
    hump333 Member
    Ive reset my Speedo miles counter and filled it up (i always use Shell V-POWER) I got 87miles till my light come on good or bad? I ride hard most times. :)
    What use guys getting?
  2. Alblade
    Alblade God Like
    Average about 140 miles to light, total from a tank almost 170+ from a tank been known
  3. hump333
    hump333 Member
    Don't think ive ever had over 100! The plot thickness :eek:
  4. kpone
    I get about 100 to the light on my 954. It's a lot older so may be more thirsty but that's a mix of around town and twistys. Hardly ever any dual carriageway.
  5. jimmy
    jimmy Member
    around 120/30 for me with quite hard riding
  6. phantomx0_1
    phantomx0_1 Active Member
    130ish to the light about 165 until the tank is almost empty
  7. megawatt
    megawatt Well-Known Member
    Hump,are you getting the bike into the higher gears? If you are , then you have a problem!!!
  8. hump333
    hump333 Member
    I think the red line is the problem:) i just love the sound as it hits ,7 to 11 rpm :D
  9. hump333
    hump333 Member
    I'm doing motorway, town,& A-Roads riding shouldn't of got the quick shift throttle!
  10. megawatt
    So you are revving the tits out of it in the lower gears and spending very little time at low revs in higher gears? Nuff said;)
  11. phantom
    phantom Active Member
    I get about 70 miles to a tank :s
    but hoping for more with the power commander fitted.
  12. martinowen
    I have an rr5 and get 90-100 before the light mate I think the newer blades did slightly more
  13. Remal
    I've had over 150 when touring so a steady 80+
    But when having a blast. Got as low as 90 miles until the fuel light
  14. paul-b
    paul-b Member
    Anything between 95 & 110 Average riding, lots of commuting ... stop start etc ... In fact always reset and light came on this morning @ 95 miles....
  15. phantom
    one thing I hate about the new blades is if it goes on to reserve
    then you stop and start the reserve counter sets back to zero
    again instead of recording the miles covered on reserve.... unless mine is faulty
  16. hump333
    hump333 Member
    Mine did the same! Is it 30miles when the light comes on? Or 50 like car's?
  17. Slick
    Slick Elite Member
    I get this only if the bike is left on the stand after the light comes on.
    From brim to reserve I get 125miles with amazing consistency, this is for a half motorway at naughty speeds plus filtering in heavy stop start traffic.
  18. steve b
    steve b Active Member
    ive had 130 and still no light on .im still not sure how it all works on the 12 plate ,more playing required
  19. Andrew
    Andrew Active Member
    My bike isnt returning any extra with the power commander fitted, but I haven't had the bike mapped.
  20. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    That sounds about right... I did a 160/170 mile round trip from full, had to fill up again and was on the light as i pulled into my drive, seemed to get a lot more out of the 600rr and that was always at 8/9K revs!!
