9.5 or 10 BPF fork springs
Discussion in 'Wanted' started by Jez, Sep 24, 2020.
  1. Jez
    Jez Senior Member
    I am after some fork springs and also a lighter rear shock spring, I do not know the rating for the standard shock spring, maybe someone can tell me, thanks jez
  2. Willie 1000rr
    Willie 1000rr Active Member
    Hi Jez,
    I have a set of 11 ohlins if any use?
    Thanks
    Willie
  3. Jez
    Jez Senior Member
    Hi, Thanks for the reply as far as I have found out fronts are 11nm standard and rear 12kg, so these would be the same as I have already, I don't suppose you have an 11kg shock spring
