93 Sticker
Discussion in 'General 1000RR Discussion' started by RepsolSam, Oct 30, 2015.
  1. RepsolSam
    RepsolSam Well-Known Member
    Going to put the 93 sticker on my Repsol..
    Any pointers? as i only get one try..
    Sam
  2. SimonRR
    SimonRR God Like
    Keep away from yamaha's with 46 in them ;)
    Use plenty of soapy water to slide it into place
  3. Jimbo Vills
    don't do it!! leave blank....
    or get your own number in same font....
  4. Carl
    Carl Well-Known Member
    If you put it on you will get kicked off of the bike when a Yamaha passes
  5. RepsolSam
  6. si1000repsol
    I did mine. Use water with a tiny bit of soap (I used washing up liquid) but make sure the nose cone is very clean. You can apply and repsosition it. Use a credit card or similar to squegee the water out from under the decal.
