Whilst giving the bike clean yesterday (rr9) I spotted this tube/pipe that I hadn't noticed before and thought that's a bit odd surely it should be pointing towards the ground? The end of the tube/pipe is resting on top of the chain guard. And what is it ?
I thought both hoses run straight down. On the rr7 there was a clip on the back of the fairing they ran through.
Thanks Barstewards for your reply much appreciated Must admit to being a little disappointed with lack of response to my post
Ones the breather tube and I forget what the other is, but they should both come down and out of this hole in the bottom. I always found when they've been in for work and the fairing off that they often shove them anywhere, not realising they come out here....as they've done on the sp
That hose should run down behind the sprocket cover like the other 2 and comes out of the hole with the other by the side stand, Lozzy arrowed needs moving back foot and a a half.
Oops sorry yes, you can see my hose coming out near the side stand....I'm not with with it lol I'm full of covid
Sorry to hear that Lozzy wish you a speedy recovery certainly seems as though the infection rates are on the increase.
Cheers Brad...quite a few of us got it now....think it was brought over the border by the Garstang bogs lads the other Sunday dirty covid spreaders
2 tubes through the hole at the bottom of the fairing near the side stand. Rad and fuel tank over flow.
I still think a wall across from about south Wales to the Wash would be a good idea to keep out the germs. I thought it should be about level with Winchester at one time but then I moved north...The Suffolk Steppes.
