ABS bleed mode help
Discussion in 'General 1000RR Discussion' started by Glenn12, Jul 18, 2014.
  1. Glenn12
    Glenn12 New Member
    Hi could anybody tell me how you short the check connector with a wire as i can't quite get my head around this and the bikes in bits.
  2. martinowen
    ColinBr did a write up on this, I think he's away at the mo but have a search for his thread
  3. Glenn12
    Glenn12 New Member
    I have the write up mate but the picture just shows the wire going into the plug under the battery which i have found but not where the other end of the wire goes. It says it is shorted with a jumper wire which i don't understand.
  4. martinowen
    Oh I see no idea then I'm affraid sorry
  5. Slick
    Slick Elite Member
    you're using SwissT's notes right?
    http://1000rr.co.uk/maintenance/16292.htm
    If you have found the jumper (under the battery, it's the only red connector there) remove the cap, you will see two terminals.
    You just need to short the two terminals with a piece of wire. Just ensure it is a good tight fit i.e. it doesn't come loose if during the bleed. Good Luck!
  6. Glenn12
    Glenn12 New Member
    Sorted thanks don't think i was getting a connection then started thinking i was doing it wrong.
