ABS Chain adjustment
Discussion in 'Maintenance' started by Kevin1, Jun 27, 2012.
  1. Kevin1
    Kevin1 Elite Member
    OK, finally got my 2012 Fireblade. All is well apart from Dealer did not PDI correctly and chain is way too slack. Handbook (can't believe I read it) says ABS model take to dealer as special tools are needed. Is this to be taken with the same pinch of salt as using genuine Honda engine oil and brake fluid etc etc? Thanks
  2. MrB
    MrB God Like
    :confused:
    Just checked my manual which covers both ABS and non ABS and it only sais to be careful not to damage the wheel speed sensor and pulser ring.
    Other than that everything normal.
    ETA - Aha I see what you mean and yes pinch of salt, crack on.
