ABS disconnect but not delete
Discussion in 'Mods, Upgrades, Accessories and Products' started by Chris Hunter, Mar 16, 2022.
  1. Chris Hunter
    Chris Hunter Active Member
    Morning - Searched the threads - lots about removing the ABS. I've just bought HEL lines and blanking plugs. My intention is just to remove the standard lines, coil up the sensors and crack on. Any dramas or tips with this? 2015 blade. Cheers - Chris
  2. Nigel H
    Nigel H Active Member
    I am in the process of doing this. Done the back but dithering about routing the hoses at the front.
    The hex head bolts used on the clips have a tendency to strip their heads and I had to drill one out.
    The big bits can come out later...
  3. Chris Hunter
    Cheers Nigel, I'm assuming its an easy job (bar the bolts you mention) remove the hoses, fit blanking plugs, coil wires and sensors up and stuff em in somewhere?
  4. Nigel H
    I was hoping to do the 'rewire' quickly without a huge strip down but I'm not quite sure how to feed the front hoses for best result.
    The shallow head soft bolts are annoying.
  5. Coda
    Coda Active Member
    I’ve just booked my first on-blade track day at Donnington so I’m wondering if I need to do this. (It’s mid April so I don’t have much time).
    Question - does pulling the abs fuse under the seat achieve a similar thing as a partial disconnect? I read in the manual that in the event of a fault the solenoids close so there is effectively a direct line from brake lever to calliper.
  6. Slick
    Slick Elite Member
    Yes, correct this is how i run mine. The light will stay on but thats an easy fix too.
    Been planning to do a full removal for while but other things come up
    Obviously you’re still carrying the extra abs junk/ weigh and it takes a bit longer to bleed but still able to do two finger stoppies so braking power is still plenty! The feel without the solenoids is great too, once bled correctly you will actually have feedback and a nice firm lever
    #6 Slick, Mar 18, 2022
  7. bazzashadow
    bazzashadow Elite Member
    Is a cb1000r 2011 the same abs?
    Some one has just brought one and I have warned him about the abs
  8. Slick
    Slick Elite Member
    Basically yes, 08/09 same, 10/11 updated abs ecu (stopped battery drain issue)
  9. Slick
    Slick Elite Member
    Just reread, cb1000r abs actually works! Totally different from Cbr abs
    cbr abs is always active, it regulates the piston pressure all the time
    , cb abs only kicks in when a lock up is detected then pulses the lever/ piston
    #9 Slick, Mar 20, 2022
