ABS Rectifier on a non ABS bike
Discussion in 'Mods, Upgrades, Accessories and Products' started by si1000repsol, Jun 24, 2018.
  1. si1000repsol
    I am looking to relocate the rectifier to the outside of the bike. The ABS rectifier has the plugs on a loom compared to the non-abs which are attached so wonder if they are a straight swap?
  2. martin_deyanov
    martin_deyanov Active Member
    Nope, plugs are different. If you are really set on doing this, your best bet is extending the wiring. But make sure you do a good solder, heat shrink, insulation job. Butt splicing will not do for the charging system. Good luck.
