Accossato / Brembo MC brake fluid reservoir Help
Discussion in 'Mods, Upgrades, Accessories and Products' started by dan.1moore1, Nov 29, 2011.
  1. dan.1moore1
    I know this has been covered guys but i can't find the thread anywhere
    I picked up an Accossato Master Cylinder at the N.E.C and got it on the bars but i didn't get a reservoir to go with it .
    I plabbed on making a bracket for my OE one but the hose is to fat . I have the pink tubing from a HRC reservoir kit but no pot with a small enough nozzle .
    Any suggestions on where to get one ?
    Or any pics of work arounds people have done with theirs would be Fannytastic !!
    Cheers Lads
  2. kpone
  3. dan.1moore1
    Nope ... Its a thread for a brembo group buy or something and somebody posted a pic of how they retro fitted the fluid res to they're brembo ..
  4. kpone
  5. dan.1moore1
    Cheers Ken .. Thats where I'm gonna end up ordering from i think
    Im sure somebody posted a pic of they're OE reservoir fitted to a brembo with a self fabricated bracket to support it .. I best to it properly i suppose and buy the proper kit
  6. kpone
    Well I'd trust your fabricating skills but it's one of those areas where the devil's in the detail...
  7. kpone
    #7 kpone, Nov 29, 2011
  8. Rp1
    Rp1 Active Member
    Yep that was me, it did the job, the bracket could of done with being made out of something a big thicker
    Have how ever just brought the correct reservoir kit to fit it, come's with new bracket, hose, reservoir clips, and mounting screws
    also got an RCS hole matching clutch assemberliy and lever to slip on, when Harris send it to me
  9. arthurbikemad
  10. dan.1moore1
  11. Nutty Tart
    Nutty Tart Well-Known Member
    Eidetic memory perhaps ?????????
  12. kpone
    No I just used the search box at the top of the screen.
    Oh. and I'm Superman.
  13. dan.1moore1
  14. CastrolCraig
    CastrolCraig Active Member
    If you get stuck send Racespares Mike a PM, he does brembo etc.
  15. dan.1moore1
    Cheers Craig
  16. JonnyAnnett
    JonnyAnnett Active Member
    We have both Brembo and Accossato fitting kits instock. They come with bracket, hose, clamps and reservoir.
  17. arthurbikemad
    I don't like them mounted on the clamp bolts looks cheap I have these but you would have to drill the yoke to fit them or it in your case, may look a bit odd on the RR8, did you see some cheap M4's on ebay too Dan go nice with your master.. :)
    ebay:-
    m4 brembo calipers off zx6r 05 | eBay
    After an age of waiting got my T Drives today.. :)
    New race spec bolts on order as these are 2mm too short and I like to use all the thread!
    Just waiting for my HPK rear now and CZ mount, then Im skint for the next three years or so! :(
    #17 arthurbikemad, Nov 30, 2011
  18. Jamiestrada
    T drives look awesome there mate. It's only money you can't take it with you :)
    That is truly the best 07 blade I have ever seen, well done that man :)
  19. arthurbikemad
    Thanks for that I have a small amount to remove off the disc spacers from the OZ wheels as the T Drives run a little close to the caliper body no big deal just need to get them to my mates mill up the road and shave 1mm of each to move them in the OEM calipers have room for a bus but not the GP's...and then wait for this:-
    And THATS IT! NO MORE MONEY!!! Dammm Honda's had it all.. :(
    So come on Dan what you doing with your master cyl res???
  20. Bats
    Bats Active Member
    Arthur i am liking your style man have we got a pic of you full bike ie plenty of nice shots?
