Okay, been speaking to the BikeDiscountStore, and have found the parts to upgrade.. Always thought upgrading brakes will help... Just need some advise to if this will make much of a difference to the braking on a 2015 blade with standard calipers? Bike is mainly used on the road, with a few track days next year.. http://www.bikersdiscountstore.co.u...adial-master-cylinder-folding-lever-pd-62.php http://www.bikersdiscountstore.co.u...cossato/pressure-brake-light-switch-pd-66.php http://www.bikersdiscountstore.co.u...to/brake-clutch-fluid-reservoir-kit-pd-80.php Looking to get it with TWM Short Levers like this: http://www.bikersdiscountstore.co.u...wasaki-folding-brake-clutch-levers-pd-164.php All is costing £252 + delivery.
Sam unless TMW have changed recently their cable clutch lever is non adjustable. I used to sell TMW on forums s few years ago and got some for my Blade only to find I couldn't adjust the clutch lever. Good quality though.
Yes they will help, how much on the road? Prob not a lot.... Mike will sort you a good deal and more importantly great service at bds, but just use the accosato levers and clutch side? It's what I have on my track bike can't fault it
You won't go wrong with accossato... Good build quality and decent products that work (and often a bit less than their bigger direct competitors such as Brembo et al)
well, good good advise from BDS - however prices they said are already reduced and cant offer anymore.. need to check if the tmw is adjustable..if not will need to look into something else.. I am sure i have seen the Brembo RCS for £180 odd from Italy? (not that much from compared to the above) also anyone know if the matching clutch is adjustable?
If anyone's after a span adjustable clutch lever, these have just arrived from TWM http://www.bikersdiscountstore.co.u.../twm-folding-clutch-lever-assembly-pd-269.php
Nice selection of colors there.. Do TWM do different color levers? So the TWM brake and clutch lever is adjustable?
The normal TMW lever to fit the standard Honda perch is not adjustable, unless they have changed them recently. If you buy the entire unit as in the picture the clutch is adjustable
