Accossato Master Cylinders
Discussion in 'Mods, Upgrades, Accessories and Products' started by broos3, Dec 23, 2011.
  1. broos3
    broos3 Active Member
    This might have been asked on here before, sorry. Have any of you guys had any dealing with these master cylinders and or can compare to the Brembo RCS item? They look great and slightly cheaper than the brembo equivalent.
    Accossato PRS Master Cylinder 19x17-19 like brembo rcs | eBay
    Im not all that happy with the feel and travel of my original MC and thinking of a replacement. Cheers
  2. Bats
    Bats Active Member
    looks good mate! i no nothing about the firm like! My RCS cost me 285 and is the best thing ive ever bought had it on me 07 blade and now my 011 abs fantastic :)
  3. Benn The Pig
    Loads of lads of the GSXR forum use them and rate them
    Highly
  4. stevebetts
    stevebetts Well-Known Member
    I do believe Dan has one of these.
  5. Givover
    Bats for those of us (Mainly me) would you please carefully explain RCS and kit /fitting /hassle/ cost /improvement ect .Thanks Mike.
  6. broos3
    cheers for the info guys. Hopefully Dan will be along soon to give his feedback on them
  7. Bats
    Bats Active Member
    Fitting easy! hassle none!! cost 285 ish!! improvement feel/travel/bling!!! ;)
  8. dan.1moore1
    Yeah very happy with mine
    When i fitted it my mate called over with his bike so we could compare it with his Brembo
    They are the same to be honest . Its just down to if you want the more known Brembo logo on it or the lesser known Accossato logo
    I paid £150.00 for mine as it is the fixed ratio 1 and I'm more than happy with it . Instant bite and feels exactly the same as my mates brembo of the same ratio
  9. Benn The Pig
    I might be up for one of them
    In the future dan, I never really been that bothered about them but the more I read the more I want one
  10. dan.1moore1
    Deffo worth it mate,, no lever travel at all , just bites instantly
  11. JonnyAnnett
    JonnyAnnett Active Member
    They are fantastic bits of kit. I'd say every bit as good as Brembo. We have sold a lot of them, and sorted a lot of race bikes out with them and they really do rate them.
    We have Accossato PRS (adjustable ratio) Master Cylinders instock. Normally £239.99 Could do for £199.99.
    Fitting kit (reservoir, bracket, and pipe) as available at £34.99.
    Cheers
    #11 JonnyAnnett, Dec 24, 2011
  12. CastrolCraig
    CastrolCraig Active Member
    Mate had one on his 1098, tried it during a couple of tame laps at cadwell, felt spongy as hell for some reason, he fitted an RCS later and it felt much better according to him.
  13. JonnyAnnett
    By the sounds of that, seems like there was air in the system somewhere. Did you try re-bleeding it?
  14. CastrolCraig
    Oh yes. Normal Bled, Reverse bled, still the same, vaccum bled, still the same. was a weird one.
  15. bluekontakt2004
    bluekontakt2004 Active Member
    If your gettin one message BikeBitsNI. he sells them on ebay for £240 so could prob do it cheaper
  16. JonnyAnnett
    See my previous post. We can do them at £199.99 whilst current stock remains.
    Cheers
    BikeBitsNI
    028 9185 9335
  17. arthurbikemad
    I think the only real BUG in after market masters for most people is levers! They need an option to match levers and that bumps up the cost.. :)
  18. bluekontakt2004
    My bad lol. quite a saving really :)
  19. dan.1moore1
    I sourced my matching clutch lever a while ago
    Bloody expensive but the same with brembo
    Strange one was spongy ?? When I compared an Accossato and a brembo if the same ratio they both felt the Same
  20. broos3
    Cheers dan,
    Where did you end up buying it from then? Im not bothered about the "Name" on the part so it sounds perfect to me. Does your brake lever have the cut outs in it like Brembo RCS?
    I will prob stick with the stock clutch lever, however where did you source yours from?
