"accurate" tyre pressure gauge
Discussion in 'Mods, Upgrades, Accessories and Products' started by Julian, Jun 4, 2015.
  1. Julian
    Julian Active Member
    been using a halfords foot pump with built in digital gauge which after tuesdays trackday has proved itself to be wildly inaccurate, recommendations for a decent gauge please
  2. barry107
    barry107 Active Member
  3. sps170373
  4. -steves-
    -steves- Active Member
    #4 -steves-, Jun 5, 2015
  5. N1xxl
    N1xxl Member
    The only sure way is to compare to a known accurate or calibrated master gauge. Digital is not any more accurate than a dial type. If your at the track get the tyre people to set a pressure then compare this to your own and not differential for future adjustment.
  6. beavis
    beavis Active Member
    I use a halfords digital one, couldn't tell you whether it's accurate or not as I've never checked it against another one.
  7. N1xxl
    N1xxl Member
    Road tyres are not as critical as long as they are at least kept not visibly soft. Fast road riders would feel the difference but track tyre pressures critical to correct pressures.
  8. Nigelg79
    Nigelg79 Active Member
    I use this for the track - reliable and has a handy pressure release valve. I use it also to check my road bike pressures from time to time before going out too - saves 50p each time! Just be sure to get the 0-60PSI version. Got it from Demon Tweeks - http://www.demon-tweeks.co.uk/motor.../longacre-standard-tyre-pressure-gauge-2-inch
    Also, well worth investing in some angled tyre valves too. I run Bridgeport valves in both my road and track bike - so much easier to get to them than having to fanny about trying to get between the discs, plus you don't need to replace them during every tyre change. Also from Demon Tweeks - http://www.demon-tweeks.co.uk/motorcycle/accessories/bridgeport-tyre-valves
