acuman dg8 gear indicator
Discussion in 'Mods, Upgrades, Accessories and Products' started by tony lomas, Sep 4, 2015.
  1. tony lomas
    tony lomas Member
    Hi guys can anyone help new member to the forum. I'm looking for a acuman dg8 kit with the loom to fit my 2010 blade .can't seem to find one any where or any advice on other products
  2. Remal
    I used the GIPpro http://www.healtech-electronics.com/products/gpds/
    Simple to fit not expensive and handy to have. Fitted took about 15 mins on my 11 plate blade.
    And I would suggest contacting the traders below as they do give a good discount . So worth knowing
  3. tony lomas
    tony lomas Member
    Thanks mate the local honda dealer told me not to use a indicator that plugs in to the diagostic port not sure why have you had any problems or are they talking rubbish cheers
  4. Remal
    Never been a issue. I know many who have used one and never been a problem. Had mine fitted for 3+ years and worked a treat every time. never a problem.
    i've not heard anything about them being a issue either.
    Anyone else?
  5. tony lomas
    tony lomas Member
    Thanks just phoned and ordered one great price all I need to do is fit any suggestions is it going under the tank etc
  6. Remal
    Nope just work out where to put it by the dash. run the wire below tank cover under seat. connect it and then get the bike on the stand and do as per instructions for setting up
    Simple and easy job
  7. tony lomas
    tony lomas Member
    Thanks for your help can't wait to try it
  8. MPJ
    MPJ Active Member
  9. tony lomas
    tony lomas Member
    Thanks mate just what a needed idiot proof instructions I've ordered my indicator £89.99 should arrive in a few days will let you know how I get on thanks again big help
  10. Remal
    It's as simple as anything. really just fowllow the instructions and bobs your uncle
  11. exuptoy
    exuptoy Elite Member
    One thing I noticed was once I fitted mine (purchased SH from here) it never went into the learn mode and just worked!
  12. MPJ
    MPJ Active Member
    The only thing I sketched on is running it in gear on the stand.... never done that, I mean 4th,5th,6th at above idle...surely still a potential disaster ?
  13. tony lomas
    tony lomas Member
    I'll let you guys know how I get on thanks for all your help much appreciated ☺
