advice and help
Discussion in 'General 1000RR Discussion' started by shaunebabe, Dec 15, 2012.
  1. shaunebabe
    shaunebabe New Member
    hi guys only joined yesterday so you will probley get fed up of me lol
    anyway i have a 2004 blade in red and black like i said in the newbie post first blade ive had so bit of advice neederd
    after looking at some post can you guys give me any tips and advive on mods and upgrades please
    read about removing the flaps on the airbox and something about a 520 conversion wood like some more info on pros and cons
    and any other advice and tips you all have cheers guys
    shaun :D
  2. thefirebloke
    thefirebloke Elite Member
    Hi Shaun, first thing I do with any bike I own is fit a power commander, K+N air filter and get a custom map fitted. This gives a bit more power (which you don't really need) but more importantly it smooths out the power delivery. Honda has never been known for getting it's fuelling right especially low down the rev range. Next on my list would be suspension, either fitting aftermarket shock or having existing re-worked and a stage one conversion on the front forks. 2004 blade is getting a bit old so you might want to look at braided hoses to enhance braking power. Last on my list would be an aftermarket can, gets you a couple of extra bhp but a hell of a lot of unwanted attention and doesn't actually improve your riding experience.
    Depends what you want, some fit sparkly, shiny bits and turn it into a tart's handbag but personally I like to try and improve the handling characteristics of the machine. Everyone's different, each to their own.
  3. Smiler
    Smiler Active Member
    First thing would be to get the suspension set up for your weight, braided brake lines all round, then maybe increase the rear sprocket by 1 tooth from orignal....... enjoy :)
  4. phantom
    phantom Active Member
    I do the mods in order of
    suspension,
    exhaust,
    flapper mod,
    power commander and filter,
    drop a tooth on the front
    then the rest is cosmetic
  5. shaunebabe
    Cheers guys thanks for the replys will keep you all updated :)
