Advice needed - do my fork bushes need replacing?
Discussion in 'Maintenance' started by Nigelg79, Feb 5, 2016.
  1. Nigelg79
    Nigelg79 Active Member
    Had oil leaking quite badly from my left fork the other day after having replaced the fluid recently. Not sure if I knicked the oil seal when putting it back together again or if the bushes are knackered.
    Here are some photos of the slide bush and guide bush - so they look ok or need changing? Advice appreciated...
  2. kev.b
    kev.b Well-Known Member
    You need to check the play in the fork stanchions, ( backwards an forward play )
  3. Nigelg79
    Cheers Kev. There's a very small amount of play, around 1mm, but no noise or knocking. Waiting for it to dry up outside then will take it for a ride after having replaced the oil seal.
