Hi has any one had any issues fitting smiths racing resets particularly the gear leaver, where you remove the engine mount bolt and replace it with the boss that's supplied i have a clearance issue gear lever catches frame looks like I need to make a spacer to move leaver 10 mm away from frame between leaver and boss
