Advice Required
Discussion in 'Maintenance' started by CBR-Pete, Feb 25, 2019.
  1. CBR-Pete
    CBR-Pete Active Member
    After five years and 44,000 hard miles my 2011 model blade has blown a fork seal, It is booked in for it's 44k service next week at my Honda dealer anyway. Spoke to them today and they want an extra £220 to do the seals, is it worth getting them done or upgrade them to the big piston Showa ones. I have a friend who swapped his over to Ohlins after 500 miles and has the big piston ones which he will sell to me for £375. I swapped the rear to the Showa one so is it worth doing the forks as well?
  2. raphael
    raphael Elite Member
    That’s a good price by your friend so I would say go for it, the only down side to the big piston forks is they can feel a bit crashy/hard but I was told you can dial a lot of that out with a good set up which when taken into account the deal your getting on the forks the extra 50 quid on top isn’t so bad in my book.
  3. nigelrb
    I get angered by the way Honda dealer charge premium prices when a good independent centre can charge up to 20% less and still do an equally good job. An EXTRA £220 is a fair swag when your bike's already there!
    If you're keeping the bike for some time, I'd grab the forks - after making sure the caliper mounts are compatible. Then there's installation! Can you do that or will you have to pay? That could change the equation.
  4. CBR-Pete
    No issues with doing work on the bike, if I can work through an ABS bleed anything is possible ;) . going to book it into MCT to have them setup anyway so extra cost there. the forks are same just black tops where mine are gold ones.
  5. sps170373
    I would say most independents are more than just 20% cheaper than Honda
  6. nigelrb
    Hey! A man's TRYING to be politically correct here.
    For once:D.
