Air box mod. Worth it?
Discussion in 'Mods, Upgrades, Accessories and Products' started by steve750, Nov 29, 2015.
  1. steve750
    steve750 Active Member
    Is the mod worth doing? Many gains/negatives?
    Is it a pig to complete?
    • Downvote Downvote x 1
  2. DCB
    DCB Active Member
    What model is this?
  3. steve750
  4. DCB
    DCB Active Member
    oops, ffs that was ment to read, "what mod is this?" not model :rolleyes:
  5. carter
    carter New Member
    Not something that's gonna add power. Did mine while it was in bits anyway, more so that I didn't have to faff every time I took the panels off. Easy to do.... does if anything feel a little smoother than the snatch it used to have from closed throttle and had a little more induction noise from the get go which is the reason for it being there to quieten it all down.
    Less what you mean is the smog plate mod then it's nowt to do with this lol
  6. DCB
    DCB Active Member
    ah ok, yip , i have done that so i could fit my new lights, but not been out since, think i will need to go back to the dyno with it after doing that anyways, pcv might be a bit lost with the air change
  7. GappySmeg
    GappySmeg Well-Known Member
    The noise... my bike sounds insane!
    The noise... I now have to wear earplugs for all rides!
  8. steve750
    Yes, that's the mod I was on about. Purely for noise regs or does it act for something else?
  9. Glb
    Glb Active Member
    Like the idea of getting rid of all that unnecessary stuff. Is there a guide knocking about anywhere?
  10. steve750
    I've searched but cannot seem to find a guide as of yet. I've read about folk just blanking it off with a screw though.
  11. scooby
    scooby Elite Member
    if your talking about the pair valve,just remove it and either fold over the tubes,tie off wioth a cable tie,or fill with silicone and ram a tight fitting screw/bolt into it,secure with lock wire,or buy the proper blanking plates.job done.
  12. Glb
    Glb Active Member
    Think I'd rather follow a guide rather than just pulling bits off haha
  13. si1000repsol
    or
    might help
  14. carter
    carter New Member
    Getting confused in here now... two completely different mods going on
