Air injection system removal
Discussion in 'Mods, Upgrades, Accessories and Products' started by Glb, Jan 30, 2016.
  1. Glb
    Glb Active Member
    Sure I've ready somewhere that the bike will fail it's MOT emissions test if it's removed.
    Can anyone confirm or deny?
  2. ShinySideUp
    ShinySideUp Elite Member
    Bikes don't get emissions tests during mot!
    I am assuming your talking about the PulsedAIR system fitted to the bike?
    Why are you wanting to remove it?
  3. Glb
    Glb Active Member
    Have heard its a benefit when changing the exhaust/filter and mapping
  4. blake7
    blake7 Active Member
    Removing it can stop any popping noises and does help with mapping. As said, bikes don't have an emissions test for an MOT, the PAIR system was used for the initial sale of the bike to get through EU regs.
    Kits are on Ebay for £25.
  5. Glb
    Glb Active Member
    Euro regulations! That's settled that then. It's coming off!
  6. ccr32
    ccr32 Active Member
    Is it the PAIR system that cuts in below 4000rpm and reduces the engine braking too?
    For instance, if you are slowing down from about 7000rpm, throttle closed, you can feel the engine braking the bike and the engine sounds smooth, then as the revs drop past 4000rpm it feels like the engine braking eases up and you hear the popping from the exhaust - PAIR system doing this?
  7. derchef
    derchef Well-Known Member
    pair must be blanked for mapping , otherwise will false the values
    i m for blank with two cilindrical plugs direct on rubber line
  8. Glb
    Glb Active Member
    Bought the blank plate kit:D
