Akra full system abs vs non abs
Discussion in 'General 1000RR Discussion' started by Moon, Feb 1, 2015.
  1. Moon
    Moon Active Member
    Anyone know what the difference is between the full system on abs and non abs?
    I did not know there was two different systems, I though they were all the same and unsure which I have
  2. charger
    charger Active Member
    if you mean difference between S-H10R6L and S-H10R7, the first one doesn't fit to abs models and/or to fairings of 12-> model abs or not.
  3. Moon
    Moon Active Member
    I think I have the 6RL version but have an abs blade. Is there absolutely now way I can make them fit?
  4. Moon
    Moon Active Member
    I emailed akrapovic and this is the reply...
    Good Morning,
    I have been passed your email from Akrapovic as we are the UK importer for their motorcycle products.
    The header pipes and Collector are different between the ABS and Non ABS models, I believe it is the ABS pump which fouls the Non ABS header pipes ( S-H10R6L system).
    The ABS system, S-H10R7-TC or TT, is the system you require.
    Kind Regards,
