Akrapovic decat slip on link pipe
Discussion in 'Wanted' started by si1000repsol, Aug 14, 2015.
  1. si1000repsol
    Looking for an Akrapovic decat slip on link pipe. Ideally in Ti if there is such a thing
  2. Blade-Rider
    Blade-Rider New Member
    Foenix has one but not Ti I think she my wanted post and his reply bud
    PS - love your blog ;-)
  3. sps170373
    All the link pipes either decat or with cat are steel
  4. si1000repsol
    Yes Foenix's is the CAT version and he sadly would be the last person I would be buying off tbh. Thanks for the heads up mate.
    Thanks mate I like doing the blog and sharing my updates.
  5. si1000repsol
    Thanks mate, had a feeling that was the case but wasn't sure.
  6. Cbrjay
    Cbrjay Well-Known Member
    On all years?
  7. sps170373
    Believe so
  8. Jamiestrada
    Yep only Titanium they did was the full headers evo or BSB spec I believe
  9. ColinBR
    Get 1 made for it Si.
    You could always borrow someone's stainless 1 for them to copy
  10. Cbrjay
    image.jpg Think mines ti, number 5 link pipe ti?
  11. si1000repsol
    Thanks mate. I assume that this is the cat version?
  12. Cbrjay
    Mines a 14 plate, cat is in headers think the bore is different size to yours. I can size it up if you want?
  13. sps170373
    Check with a magnet, if it sticks it isn't ti! Even stainless has enough iron in it for a magnet to be drawn to it, also the weight will give away the material
    the link pipe I've just taken off the anniversary akra can weighed more than my entire racefit can which was titanium
  14. Cbrjay
    Magnet won't stick to my link pipe, not discoloured like stainless. Just gone a bit blue from heat.
    My full ti arata on 600 weighs less then my yoshi end can
  15. Repsol_Dan
    Repsol_Dan Active Member
    Any luck with this as I'm also after one?
  16. brg1000
    brg1000 Active Member
    I have one for sale in the for sale section.
  17. Repsol_Dan
    You have the can and link pipe with cat, we are both after the link pipe with out cat
  18. brg1000
    I can remove the cat quite easily
