Guys, I understand this is the correct one for the 2016 Black Edition, I want the CF one in black obviously to match my (hopefully) new ride. http://www.jhsracingstore.co.uk/PBSCProduct.asp?ItmID=14252470 Anyone, know if I can get remove the baffle from this easily? Is it best done before fitting? I found the baffle removal on my CBR 650F a pain as it was wedged in good and resulted in some 'teeth' impressions on it from the lever. Also, can this be purchased cheaper anywhere?
If the can is e-marked, then the bolt holding the baffle on Akra's (in my experience) is tack welded in. It can be removed with a bit of gentle persuasion / an impact driver, but be very careful not to damage any of that lovely carbon..!
