Akro downpipe cleaning
Discussion in 'Maintenance' started by keithg1748, May 20, 2016.
  1. keithg1748
    keithg1748 Active Member
    evening , I got home tonight after a bit of a blast I was nearly home and I could smell burning , got home had a look round bike and found this on the downpipes and haven't a clue what it is ? ive tried a few things to clean off and it wont touch them , any ideas because they look shit , thanks for any info. 20160520_191015.jpg 20160520_191005.jpg 20160520_191040.jpg
  2. Lukes07
    Lukes07 New Member
    hi buddy, i use a wire brush along with solvent cleaner brings them up immaculate, also the wire brushes you can put in the end of a drill works much faster !
  3. keithg1748
    what solvent cleaner ? that's for your advise.
  4. Lukes07
    Lukes07 New Member
    I just used a cheap one from b&q buddy not sure of the name any should be fine that's what I used
  5. keithg1748
    thanks , it looks as though something has come off the road and melted on the pipes , ill have a look.
  6. Sean M
    Sean M New Member
    The last comment 'any ideas cause they look shit' did make me chuckle.
  7. Sean M
    Sean M New Member
    Little things please little minds...well in my case they do. Lol
  8. rebel
    rebel Active Member
    if there made of stainless this is what you need absolutely brilliant stuff 2016-05-22 16.53.29.jpg
  9. keithg1748
    I don't know what they are it was on the bike when I got it , how do I find what they are . thanks.
  10. lambchops
    lambchops Elite Member
    That's going to take some shifting.. Wire brush in the drill will work and be the quickest option. Removed some similar shite from mine last week! If they are genuine akro headers will be titanium, standards are steel, wire brush will work on either. Finish the clean up with autosol, but be careful you may make a clean spot :)
  11. lexathon
    lexathon Active Member
    Can't help but feel sorry for the poor cat's owner.
  12. keithg1748
    thanks mate but did you remove them or did them on your bike ? what wire brush steel or brass ? clean spot ?
