Has anyone got a good close up of the Akro slip on showing the main strap bolted up and the spacers required on standard foot pegs 2008 onwards.... Just trying to help out a fellow member........ cheers
Link to instructions .pdf in this thread http://1000rr.co.uk/mods-upgrades-accessories-products/12335.htm
Thanks for the thread Rob, and the info guys.... I couldn't fathom how it all went together this morning 5mm spacer hunt is on
No...... you ll hardly notice it unless your right leg is already 10mm shorter than the left !!.......
is it the 2 - 5mm spacer on the brake side ? rearset into frame , do you have issue with the bolt as I fitted gilles to mine and the brake switch was catching the bolt , so I doubled the 2 spacers up to 10mm and put a flat ended bolt in and it was fine.
