Aldli Torque wrench
Discussion in 'General 1000RR Discussion' started by Mad Matt, Oct 12, 2014.
  1. Mad Matt
    • Like Like x 8
  2. jamesm09
    jamesm09 Senior Member
    I'd pay a bit of money for a torque wrench Matt. I bought a cheaper one a few years ago and it failed the calibration test. Don't know if it was a one off or not. But paid for a decent one and passes every year.
  3. Remal
  4. megawatt
    megawatt Well-Known Member
    I bought a Lidl one last year. I believe someone carried out cal checks on Lidl, Aldi, Norbar and a couple of others. The Lidl and Aldi ones were the most accurate!!!
  5. sinewave
    Any old shyte will pass a Cal Test when new, only quality gear will pass consistently after reasonable use.
    Buy the Teng one's, they are quality kit at very reasonable prices.
    I have 3 of the Tengs and they are top draw.
  6. megawatt
    What do I know. Only been an engineer for 38 years and been working on road bike and race engines for the same amount of time. I give up. Just spend loads of money on stuff you don't need, so you can tell everybody you bought the so called best.
    • Like Like x 6
  7. Alblade
    Alblade God Like
    Thing is, Aldi and Lidl in Germany (where both are based) have a great reputation and much of their special stuff like this is Germany made with very good warranty cover etc.
    I bet they come with a 3 year warranty - will be good enough for many from here I am sure
  8. sinewave
    In that case you'd have noticed that the Aldi unit appears to be a 3/4" unit and thus it's Torque range will be too high for most applications on a bike bar Axle nuts etc.
    Like the 'Top Quality' kit some portray it to be I see it lists nowt useful like it's size or Torque range?
    Still what do I know, however U could bet ya Pension you'd not find an Aldi Torque wrench in many Pro Garages throughout the UK
  9. megawatt
    They are good enough for most of the people on here who use a torque wrench maybe once a month, if that.
  10. Frost1
    Frost1 Active Member
    Looks 1/2" to me especially with those socket sizes supplied, but info would be good.
  11. scooby
    scooby Elite Member
    so what torque wrenches do you use?
  12. scooby
    scooby Elite Member
    i've just clicked the link on the aldi ones,i've actually got 1 of those,had about 6/7 yrs.doesn't get used a massive amount as it's torque ratings are a bit to big for the bike.and tbh no idea how accurate it is as i've never had it calibrated.Also got a 3/8 norbar which i use for the bike,again though,no idea how accurate it is now 3yrs on as never had it calibrated to see since buying it.
  13. RRoss
    RRoss Active Member
    With the sizes of the supplied sockets i would assume these are aimed at checking wheel nuts on cars,maybe suitable for rear axle nut on a bike but everything else would require a 3/8 torque wrench.
  14. wedgiewolves#223
    wedgiewolves#223 God Like
    I have a snap on digital 3/8 drive does 5.8 NM to 135nm so does all the range the snap on van has a tester fitted to van so test the torque every now and then . Need calibrating once on 2 years
  15. Remal
    Not saying you don't know your stuff and Aldi or lidl gear is not good. Anyway who said Teng in the best stuff and so call best? Everyone has their view and the BIL loves his Snap on Torque and has used it daily for his work but I'm not about to spend £300 on 1 ;)
  16. Muffking
    Am I right in thinking that they last longer if you wind them out to release the tension after use?
  17. Mad Matt
    You should always do that...
  18. wedgiewolves#223
    Yeah always take tension off the spring correctimundo
  19. Muffking
    I'm glad it's not just an urban myth then :D
  20. sinewave
    I do that with my Bike's suspension after every ride! ;)
