all about fluids
Discussion in 'Mods, Upgrades, Accessories and Products' started by racman, May 15, 2013.
  1. racman
    racman Active Member
    weather crap as norm, so put hel front and rear brake lines on. bled system up. while i had the gear out, thought i,d replace the clutch fluid as well. all went swimmingly well. all i need now is a bit of good weather to test ride
  2. jokeshopbeard
    jokeshopbeard Active Member
    What method did you use for bleeding out of curiosity? I've tried many, all of them not quite perfect, thinking of going for speed bleeder nipples next...
  3. SpeedoX
    SpeedoX Active Member
    Excuse my ignorance - what is clutch fluid?
  4. moab78
    moab78 Active Member
    2004 - 2007 blades have hydraulically operated clutches, which use a similar system to the brakes.
    #4 moab78, May 15, 2013
