All Balls Racing...
Discussion in 'Maintenance' started by Blackness, Jan 22, 2015.
  1. Blackness
    Blackness Active Member
    Hi..
    Has anyone used All Balls wheel bearings ? Changing mine and finding a lot of places are selling these ! They say they are manufactured to ABEC 3 precision levels, what ever that means... Anyone know if thats as good as originals ?
    Cheers G
  2. red5
    red5 Well-Known Member
    Oem or standard bearings are generally ABEC1, so in answer to your question at the very least they will be equal to OEM, in tolerance anyway.
    Personally I would just buy from a local bearing supplier.
  3. wedgiewolves#223
    wedgiewolves#223 God Like
    Used all balls bearings in my spare wet wheels on my zx636 all seemed good
  4. Blackness
    Cheers guys, that'll do for me !!
  5. callumw
    callumw Active Member
    I can't testify to their quality yet, but I fitted some to mine a few days ago. I did a 20 mile shake-down run (scrubbing in new tyres) before re-torquing bolts and they felt smoooooth + it's tightened up the frond end (ooer missus).
    Mind you my old set were so shot that anything would feel better:
    http://www.1000rr.co.uk/threads/what-tools-to-replace-front-wheel-bearings-08-11.28937
    If you do it yourself, I'd recommend using a blind bearing puller .... or take the loose wheel and new bearings to a friendly mechanic to swap.
    If you try the screwdriver/hammer approach then you'll probably score the inside of the bearing spacer which is £19 new from Honda ;)
    Also, if you use a front head paddock stand then it'll probably be in the way of the front axle, so you'll need to use a front fork stand.
  6. sp1n99
    sp1n99 Active Member
    When I rebuilt my kart engines back in the day I always put the bearings in the freezer overnight, bit of gentle heat on the bearing housing ( hairdryer or heat gun ) and Bob's yer uncle they used to just drop in.
