Annoying Buzzy vibration RR6
Discussion in 'General 1000RR Discussion' started by Blackness, Mar 30, 2014.
  1. Blackness
    Blackness Active Member
    Hello Chaps..
    I know this is a long shot and could be anything but its worth a try !
    Over the past few months i have noticed an annoying buzzy vibration coming from somewhere around the cock pit area as soon as i hit 5000 revs and goes by 6000... I have listened everywhere when revving it, rode along holding everything trying to pin point in but, alas, no...
    Sounds kind of around the ignition area... Thought it might be the key, but no... Pre load adjusters rattling, no.. clocks, no.. And so on...
    Is there anything in the HESD that can vibrate and buzz ?
    Has anyone else had this and found something I've overlooked ?
    Its at my "gentle cruising" rev range and its seriously doing my head in now :/ ! Please, someone, stop the buzzing :(
  2. garyauk
    garyauk Active Member
    My rr7 used to do that all the time, but mine was the after market screen. I even took it off and put it back on again. And.............................it still buzzed!
  3. sps170373
    Try ear plugs ;)
  4. Blackness
    Right oh, cheers buddy, ill be screen checking tomorrow but sure mine is lower down... It plays with my head and seems to move just as i thought i found it :/
    Yeah, ear plugs have now been issued, but I'm not gonna let the lil bugger beat me !
  5. dave d
    dave d Elite Member
    Take a screwdriver out with you and start pressing it against various things.
    Good luck.
  6. GSP
    GSP Active Member
    Mine used to do that all the time. It was the tank cover vibrating, try pressing down on all parts of tank cover and it will hopefully be the problem.
    You can resolve it by placing a piece of thin foam between the tank cover and tank.
  7. Blackness
    First prize goes to garyauk !! It was the feckin powerbronze black screen ! Im hoping reinstalling it with some silicone sealant will shut it up !!
    Thank you all for your suggestions...
  8. garyauk
    Haha, glad I could be of some help......its nice to know that somebody is listening to all my waffling.
    Maybe coincidence, but my screen was a double bubble Powerbronze dark tint screen,
  9. Gilesy
    Gilesy Elite Member
    I had the same a while back.. it was the clock bracket that had slackened off.. try and tighten every nut and bolt under that clock bracket and I'm sure this will fix it..
  10. Blackness
    Cheers Gilesy, and i will give em a tweak too but when I'm riding at 5000rpm and the buzzing starts, if i put my hand on the screen it stops !
  11. Gilesy
    Gilesy Elite Member
    was exactly the same symptoms I had..
