Another HM Plus
Discussion in 'Mods, Upgrades, Accessories and Products' started by Swiss T, Mar 4, 2014.
  1. Swiss T
    Swiss T Active Member
    Finally got around to installing it Arthur.
    Thanks pal.
  2. Mad Matt
    Did you have any issues fitting it Swiss??
    I managed to fit one to my R1 and found it easy but believe its a tad more difficult fitting one to the blade.....
  3. arthurbikemad
    Looks great :)
  4. Swiss T
    With the Blade Matt, its just a question of getting to the coils; you have to remove a fair bit & the space around the coils is limited. Its not difficult, just takes a while. Also, the instructions don't give much guidance on installing the strain gauge; I guess you have to work out whats best based on your setup. They can be mounted either way up but I went with cable at the bottom because the thread from the top rose joint is quite long & screws further into one end of the strain gauge than the other.
    I should really have fitted the other supplied nut (so there are two) in the joint between the strain gauge & the new shorter rod, to allow for adjustability; I will get around to it at some point. I think I can also tidy the wires up a bit but I'm leaving that until I'm happy with the position of the control box; I need to make sure my knee doesn't catch it & I cant help but think it would be better near the clocks.
  5. webbie
    webbie Active Member
    Whats your feedback on this ?
    I was at padgets Honda on Monday and clive was showing me one
