Answers on a postcard please
Discussion in 'General 1000RR Discussion' started by rosier1uk, Mar 31, 2014.
  1. rosier1uk
    rosier1uk Active Member
    Hi Guys
    Am a little bit curious whilst fitting a pc5 on my mates repsol blade had the 2 bikes side by side and noticed the difference in size of the 2 bikes the repsol is a 2011 10k miles and the hrc is a 2009 with less than 2 k on it,both have exactly the same suspension settings on them but as you can see in the picture theres a noticeable difference in height at back end and tank the floor is flat so not that and both bikes in line
  2. Nick_BladeRR
    Nick_BladeRR Active Member
    Now we know why the Repsol riders claim to be faster their bikes are smaller! lol.
  3. rosier1uk
  4. ColinBR
    It's possible the Repsol has had a lowering kit fitted.
  5. martinowen
    It looks as if the repsol is just leant over a tad more on the stand which is making it appear lower
    (Repsol's obviously naturally have better lean angles)
  6. Ratser
    Ratser Well-Known Member
    Repsol has a flat rear tyre. ;)
  7. rosier1uk
    No lowering kit Colin both standard
  8. Si.
    55 rear and a 50 rear?
  9. rosier1uk
    Both 50 rear Tyres
  10. rosier1uk
    Both tyre pressures the same
  11. Mad Matt
    Obvious, im new to blades so thought you guy's would get this rather than a newbie like me....
    Its the curvature of the earth of course;)
  12. Great Guy
    Great Guy Well-Known Member
    The Repsol is a 600
  13. sps170373
    Just an optical illusion I reckon unless you've actually measured them?
  14. The.kickboxer
    The.kickboxer Active Member
    Tilt the picture to the left so the floor looks horizontal, the blades looks the same like this.
  15. travellingkiwi
    travellingkiwi Active Member
    The repsol is either further away or has a smaller rear wheel than the HRC... You can see the repsol rear wheel looks smaller (Or the photo is taken with the camera tilted... Which the edge of the floor suggests... Or it could be an aberration by the zoom being all the way out on the lens...
  16. dave d
    dave d Elite Member
    look how the brickwork on the back wall slopes down to the right!
  17. sps170373
  18. Black
    Black Active Member
    Swap them round and the Repsol will be bigger. try it, you'll see! ;)
  19. Pete H
    Pete H Active Member
  20. Blackness
    Blackness Active Member
    Funny that... Kinda explains the symptoms of little man syndrome I've noticed from some repsol riders in the past ;)
