Any builders/felt roofers on here?
Discussion in 'Lounge' started by megawatt, Sep 20, 2012.
  1. megawatt
    megawatt Well-Known Member
    Need to refelt my porch roof and want to know how to do a Welted drip edge properly?
  2. kpone
    I have felt the odd roofer, if that helps...
  3. Garyb
    Garyb Moderator.
  4. barry107
    barry107 Active Member
    If your no good with a gas torch, you have the option of using a GRP trim which you fix (screw or nail) to the surface and torch your felt too. You can either use a watershed or non-watershed trim depending on if you have an outlet on your pourch roof or a gutter fitted around the perimeter.
    Fairly easy to do a welted drip edge, depend on how far down your guttering is fitted if at all and how far your over hang is (you may need some wooden battens).
    You need;
    Drip card, this made from hard board and you can get it in different widths or you can rip down some suitable ply to the width you want/need
    Galv clout nails
    Felt primer to paint the hard board or suitable ply.
    Cut felt into suitable strips i.e. long enough to wrap around board/ply and lap onto the roof surface.
    F*ck typing it all out, pm me and i'll come over have a look to see what you need, source what you need from the yard if I have it, tell you what you need to buy if I don't have it and give you a lesson on how to install it or do it myself if your crap at it :D.
  5. megawatt
    PMd you mate, but you need to delete some old ones before you see it. You still got my moby number?
  6. barry107
    Old pm's cleared out now.
    New phone so don't have your number, lost old phone and sim card :rolleyes:
  7. megawatt
    Will bell you after 1000 mate. Also thanks to Gary:D
