My car wouldn't start this morning :-( Was driving fine yesterday as i drove home from work. Gets up for work this morning and its not starting. The battery is strong and you can here the starter motor whirring away. I think it may be some sort of sensor that's gone. Its a Vauxhall Corsa 2009 1.2 SXi with 57k on the clock. Any ideas would be great thanks
My mums 1.2 corsa did this last year Turned out it was the fuel pump relay Sent from my iPhone using Tapatalk
Should be straight forward to diagnose being a petrol. Are there any errors? Do you have a plug in diagnostic tool?
Can you hear the fuel pump running when you switch the ignition on? If not check for fuel cut off reset button ( Google for exact location) I'd check that first if it were mine
From looking it could be a fuse not a switch on the later ones. Worth a look before going into bigger more expensive options
That'd be where if be looking first switch/ fuses, then relay, then finally pump not done much on the later stuff tbh but that's the way I'd be looking
Cool ill look at some fuses and relay's etc One guy said it may be the Crank sensor so i'll try and check that too
100% crankshaft sensor!! Friends one had the same last year and it's well documented, changed it for her in about 30 mins, you need to get the car as high as possible and climb under and to the back of the engine, towards the bulkhead.
