As title, I need a fabricator to fabricate 2 brackets that fit on the rear subframe under the seat. One end connecting by where the rear seat strap goes , the other connecting to the end if the subframe, i need one for each side?its to thread my kriega us20 luggage strap as my new tail end is too thin just to rely on the seat. Anyone up for the blue Peter challenge??? Thanks a lot.
Megs... I'll take photo, and draw up the bits i want making mate, if thats ok? I am just a matchsticks men and women kind of drawer dude.... therefore, i'm basically shit at drawing lol.
This ok? Basically, i need to have the webbing of the Kriega bags underneath a bracket to make it secure. The bracket can either be a sturdy D ring ( 4 of them) or a bar that connects via the bolt holes indicated, but goes towards rthe back oth bike. The webbing needs to go where i've put it on the picture mate. The webbing is supposed to go around the subframe, but as you can see, theres no subframe space to thread the webbing through, so brackets or whatever need to be made. This ok??
Sorry mate I'm still gonna need a drawing. Are those holes a M5 or M6 thread and are the centres of the holes 77.5mm apart??? So do you want a bracket 87.5 plus as much overhang as can fit in the end gaps? How much room is there either end? How thick and how wide do you want the brackets. I have various widths of stainless! If you do a drawing, post a picture of it on here?
Yeah, centre of holes 77.5mm apart mate… m6 or m5..dunno lol (maybe someone can help??) …told you i was pantys. the holes are 5mm wide? that make it an m5?
Have I got it right in my head Si, you basically want two plates that run under the seat unit and protrude a little with D rings so the forces applied on the Kriega straps when tightening down are applied at the end of the supports rather than the actual seat unit? I think I know where your coming from mate?
Probably M6. I need you to measure how much clearance from the edge of the holes to the bits in the way?
Looks like D rings might be stronger. How you gonna fix the rear webbing? Through the rear D rings? 4 of these?
My drawings are shit. LOL The d rings or brackets need to angle out mate, as the webbing needs to be central for stability. at the rear end hole, i have around 300mm to play with due to the subframe in the way. You can see where the webbing will be placed as in the pic (not the drawing)
