any home DIY'er?
Discussion in 'Lounge' started by bonjo, Mar 28, 2024.
  1. bonjo
    bonjo Active Member
    Have to replace the kitchen sink.
    Would like to get a slightly larger on so..
    What is the best way and tool to enlarge the existin cut out.
    I have electric drill & jigsaw in addition to a selection of tools
  2. TheGodfather
    TheGodfather New Member
    That should be all you'll need
    • Agree Agree x 2
  3. Muffking
    • Agree Agree x 2
  4. bonjo
    bonjo Active Member
    Thanks by wood you mean the worktop chipboard?
    sound like I’ve got the tools now have to look for the missing skill;)
  5. Jez
    Jez Senior Member
    On a good day they come with a cutout template to put on your worktop
  6. bonjo
    bonjo Active Member
    thanks gents.
    My next step is to take out the old one (would you beleive it, the dishwasher has to come out first:mad:) To see what I am in for.
  7. TheGodfather
    Yes you will have to if the previous sink was held in with clips. 99% of the time I just bed new sinks down on silicone. Most sit flat but if not you can weigh them down overnight. Also seal the chipboard cut out with silicone to seal it.
  8. bonjo
    bonjo Active Member
    Well I have now bitten the bullet. The cut out need to be slightly enlarged. I will know exactly whne the new sink arrives.
    First major issue, the dishwasher is stuck and no amount of force from my lightweight body makes any impression. As half of the cut out is above it, it will be a tricky job!
    I think the house has shrunk since the appliance was fitted:eek:
  9. Muffking
    Is it stuck at the top and bottom, or the sides?
    If it's the top and bottom then you need to make sure the feet are wound up.
  10. bonjo
    bonjo Active Member
    Plenty of clearance top and bottom, the adjustable feet all ok.
    It is the sides like a seized brake disk!
    I remember the fitter took the side panel off at the time so that it would fit.
    Just have to cover the top properly when cutting the worktop. I may have to omit a couple of the retaining clips as it is not possible to tighten them:rolleyes:
  11. TheGodfather
    The cabinets and door absorb moisture from the dishwasher, hence could be tight. I always leave 2mm extra to compensate for this. If you can fit the sink without taking it out then why not.
