Any ideas how I can get this F**ker out??
Discussion in 'General 1000RR Discussion' started by Yorkshire Tyke, Aug 24, 2016.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
  2. sulaco
    sulaco Active Member
    Loads of vids on youtube, my first option would be cut a slot in the end with a dremel, try a bit of heat and screwdriver it out. Next would be slip a nut over it as snug as poss and weld it on, then put a socket or spanner on it. Drilling re-tapping not my fav but is an option, depends on your skill level really.
  3. blake7
    blake7 Active Member
    Weld a nut on the end and then with heat applied unscrew the fecker out
    • Agree Agree x 3
  4. lexathon
    lexathon Active Member
    Try soaking it in wd40 before anything else - give it a chance to penetrate.
  5. Carlo
    Carlo Active Member
    I did the same to a cbr 600rr a fue years ago.
    If you can get some heat into it with some WD40 and if your lucky mole grips will get it out that's what I used.
    If not weld a nut on is the safest bet. I dont like the idea of cutting a slot into it due to the fact it will be nearly impossible to get a good hold on the screwdriver between the radiator and the exhaust port too much risk involved with that for me ie rounding the thing off even more.
  6. sps170373
    Had a same problem tyke when I changed my headers over and snapped one when doing back up! Mole grips and lots of heat does the trick
  7. auag
    auag Active Member
    If it's steel in aluminium then use 50/50 acetone/ATF.
    Orientate so it can soak, keep applying for a few days if necessary.
    If still tight use neat acetone.
    A glass eye dropper from the chemist is a good applicator.
    Heat helps, if you dare use, depends on the tolerance.
  8. Geoff Paxton
    Geoff Paxton Member
    Grind flush, centre mark get helicoil kit drill out tap fit helicoil.
