Any ideas
Discussion in 'General 1000RR Discussion' started by shaunebabe, Jun 22, 2013.
  1. shaunebabe
    shaunebabe New Member
    Hi guys wondered if you can help me
    Brought a 2004 blade RR last September totally standard wen I got it
    Running fine no problems
    Recently fitters new plugs air filters and a scorpion exhaust
    Now the problem is runs fine up until I get to 8000 revs then it starts hesitating as if its misfire ring but its not it never did this before until I've fitters new stuff
    I no it's not a misfire it's asif it's being restricted
    So was wondering as any one got any ideas thanks in advance Shaun
  2. martinowen
    Check you haven't kinked the fuel line when lowering tank back down
  3. sinewave
    Almost definetely a Fueling problem.
    If it's not a kinked or semi kinked hose then the tank was full-O-shyte/rust etc and lifting it up has disturbed the shyte and it's now causing Fuel starvation on higher revs.
