anybody with Gilles VCR rearsets fitted?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Dano28, Apr 19, 2013.
  1. Dano28
    Dano28 Active Member
    Hi need a close up pic to see how the shift rod is attached to the gear shift lever if possible please...
  2. jimmy
    jimmy Member
    this any good to you ?
    if not i can get a few closer ones tomorrow
  3. Dano28
    Hi Jimmy, thanks for that if you could get a closer one tomorrow that would be great, I'm after a close up of the bit that holds the bottom of the shift road with the ball joint to the black gear change lever. Mine has a bolt through the front and nut on the back which I'm pretty sure looking at yours and others they don't have. So trying to find out how mine should look. Cheers Dan
  4. jimmy
    jimmy Member
    Any better ? no nut and bolt there..
  5. Dano28
    Cheers Jimmy, that's great mate how's it fixed into the black foot gear shift? Mines 2nd hand so might have to see if I can get hold of a schematic or fitting instructions and have a butchers... Not got bike here at the min it's off getting painted so might have some more q's once it's back if that's ok?
    Cheers Dan
  6. jimmy
    jimmy Member
    Dan, its real difficult to see how its fixed but I think its screwed via a hex/allen key type..
    Looks simple enough though.. Just give me a shout if you need any more pics/info
