Anyone any good at making baffles?
Discussion in 'General 1000RR Discussion' started by bluekontakt2004, Dec 8, 2011.
  1. bluekontakt2004
    bluekontakt2004 Active Member
    Got this exhaust on my 05 blade. Imported from the states.
    Its not overly loud but quite loud. Am planning a trackday at oulton park next year and they run a 102db limit which i dont think i will make.
    Its not designed for baffles as the two exits are reasonably small.
    any ideas?
  2. bluekontakt2004
    Failing that i may remove it and sell it and just buy a beowulf oval with removeable baffle. The sale of this can should pay for that and still have change left in my pocket.
  3. CastrolCraig
    CastrolCraig Active Member
    Yup. get it sold and buy a beowulf
  4. bluekontakt2004
    lol, I actually like tis can though. Its the only one that fits the gap under the seat without leaving any gaps. all the others just look like tupence bolt on extras.
  5. megawatt
    megawatt Well-Known Member
    I make baffles mate. I will need accurate measurements , good clear pix or the silencer???
  6. bluekontakt2004
    I will dig the bike out the weekend and borrow the micrometer from work.
    you can here the bike at the end of this video. Me touring scotland. just after the applecross road.
  7. megawatt
    Ok mate, how quiet do you want it?
  8. bluekontakt2004
    under 98db so I can do quiet trackdays. will remove after trackdays.
  9. bluekontakt2004
    If thats not possible just under 102db and I will skip the 98db days. (normally weekend hero days anyway lol)
  10. megawatt
    If it's the can on the bike doin the filming, it don't sound exceptionally loud mate. If you can get to a trackday meet one day, they will test it for ya without you having to pay?
  11. bluekontakt2004
    nope, You see me pull away at the end at about 12:27. The camera bike is a cbr600f with a stock exhaust ;-)
    Then a 918 blade goes by with a stainless oval with a baffel in. Can tell mine is 10 times louder.
  12. megawatt
    Now I get ya, yep that's loud. I can make you a baffle to get you through the noise tests and run OK on the road, but you would need to alter the fuelling with a PC for the trackif it's already been set up for that can? Can you do another drive by video?
  13. bluekontakt2004
    Blade is off the road at the moment. I think the baffles will help it as the bike has no power comander fitted. I am planning on buying one but looking for cheap ones on ebay lol.
    The bike bogs down in first gear when trying to pull away quick. so baffles might actually help it breath normally.
  14. bluekontakt2004
    Im a bit dubious if it would make a 105db day aswell in the current form. only td ive done on it was donnington on a noisy day so no sound test.
  15. bluekontakt2004
    Right, Measurements.
    inside diameter of pipes
    left side is 39.26mm
    right side is 39.35mm
    wall thickness of pipe is 1.3mm
    10mm of pipe sticking out of end can.
    Hope that is enough dude.
  16. megawatt
    I'll check my stock mate . Need length of baffle mate n some pix. PM yer number for a chat?.
  17. bluekontakt2004
    Random pic found on net, But its the same zorst as mine.
  18. bluekontakt2004
    Its going to be next to impossible drilling those outlets isnt it?
  19. megawatt
    Can you undo that endplate?
  20. bluekontakt2004
