Anyone have Bazzaz Z_Fi R-77 Yoshi map. Baffle & Baffle out.
Discussion in 'Mods, Upgrades, Accessories and Products' started by exuptoy, Jun 24, 2015.
  1. exuptoy
    exuptoy Elite Member
    Does anyone have a Bazzaz map for a Yoshi R-77 for baffle in and baffle out. I'd like to compare these and see the difference. looking at purchasing a Bazil and would like the option for both.
    Also whats the best switch option for changing over maps, including the bracket for the switch. Any recommendations.
  2. Moon
    Moon Active Member
    I use the bazzaz switch with the TC adjuster mounted with a brake reservoir bracket on the left clipon
  3. Moon
    Moon Active Member
    I will be using my maps for baffle in and out but have not made a baffle in map yet
  4. exuptoy
    ;) What about the switch? Is this a Bazzaz special?
    Anyone have the maps?
  5. exuptoy
  6. Moon
    Moon Active Member
    I used the bazzaz one as its plug and play and I can adjust TC on the fly.
    You can change the maps by inserting or removing a plug which basically just has a wire bridging it, this came in the box with the unit but you would have to remove seat etc to get to the plug to change it. I guess this would work if you were not in a hurry to change maps and don't want to adjust the TC if you have it.
    I've been building a map for r77 full system and BMC filter baffle out, not made a baffle in map yet. You can download maps from bazzaz website which users have uploaded as well
  7. exuptoy
