Anyone here got access to a Haynes Manual
Discussion in 'General 1000RR Discussion' started by samuk, Jul 12, 2012.
  1. samuk
    samuk Well-Known Member
    #1 samuk, Jul 12, 2012
  2. martinowen
    What do you need mate?
  3. samuk
    Thanks Martin..I have the PDF version somewhere just trying to find it..
    I need to know how to connect the servo wires..
    Heres one on ebay..2 cables connect to the silver bit - the other end goes to the standard exhaust..
  4. Carl
    Carl Well-Known Member
    If its an 04-07 Haynes I can sell you mate ?
  5. samuk
    sell me or tell me? its for a rr5..
  6. martinowen
    I will have a flick through mine quick
  7. samuk
    thanks, check the exhaust section maybe...
  8. martinowen
    You on about the cables that open the valve in the exhaust?
    Or have I got the wrong idea?
  9. samuk
    yep thats the ones..2 cables
  10. martinowen
    Hang on found it, I will post a pic if that helps mate
  11. samuk
    thanks
  12. martinowen
    Any good?
  13. martinowen
    Or this may be more helpful, write up of cable renewal and another pic
  14. samuk
    thanks Martin, just waiting for my brother to check this as he will be fitting the cable for me
  15. samuk
    Does it say the servo needs to be removed to get these 2 cables in?
  16. martinowen
    Can't see it in there its more about maintenance and ajustment, it says about removing the cover
  17. martinowen
    Any luck?
  18. JM1
    JM1 Active Member
    Another pic
