Arai chaser helmet issue!!
Discussion in 'Lounge' started by blade1980, May 25, 2014.
  1. blade1980
    blade1980 Active Member
    Purchased this helmet around a couple of months ago, with one thing and another only been out a few times and each time after about an hour my head is in agony, I have a bright red strip right at the top of my forehead once removed?? Seems like too small or rubbing? They checked it in the shop and says it's right size when I bought it!! Any ideas????
  2. Givover
    Have you got it on " back to front":D
  3. Barstewardsquad
    How many times have you worn it? My Viper GT took about 5-6 hours to break-in. It fitted perfectly in the shop but did give me a bit of grief on the RHS of my forehead until bedded in.
  4. blade1980
    Around 3-4 hrs at the mo, surely this is more than breaking in ??
  5. Barstewardsquad
    Should be OK. Who did you buy it from? Most places won't exchange lids :(
  6. blade1980
    I'm aware of that, got it from the sportsbike shop in Boston
  7. Barstewardsquad
    Could be lucky as they are normally pretty good about returns.
  8. Ian E
    Ian E Active Member
    I had the same problem with my Chaser V (previously had Viper and Quantum and they were perfect fit). I took it to the Arai Technicians at the TT last year and they used a small roller to compress the inner helmet where it was rubbing. It is a lot better now.
  9. The.kickboxer
    The.kickboxer Active Member
    May be the right size but not everybody has an Arai shape head. I have a v comfy AGV but the new one kills me or is too loose :(
  10. Stevie_d
    Stevie_d Senior Member
    I'd give it 2 months, mine fit like a tight gove then 2 months later was comfortable rather than tight, otherwise you may have a size too small or even a Martian shaped head ;)
    #10 Stevie_d, May 26, 2014
  11. blade1980
    I had an arai rx7 corsair before in the same size and there was no issues with that one
  12. Kentblade
    Kentblade God Like
    Take it to a shop with an Arai trained person. If its just reshaping and padding removal, they will do a custom fit.
