AVS Levers problem
Discussion in 'Mods, Upgrades, Accessories and Products' started by HRCTrev09, Apr 14, 2012.
  1. HRCTrev09
    HRCTrev09 Well-Known Member
    Hi guys i fitted AVS levers and everythin went fine but the clutch lever had loads of slack with the clutch adjuster (upper) at the original setting so i wound it out till there was no play but now it's a work out using the clutch!..:eek: I'm gonna end up with a forearm like popeye :eek: !!!.. Is this normal or do i have to adjust the lower adjuster?
    I know some you's have the same levers so i will gratefull for any help :)
  2. BLAGGERS
    BLAGGERS Well-Known Member
    Mine's wound right out too, but I only need to pull it in a small amount with 1 finger. Dunno what you have though, cable or drybollick? Mines the latter so could be the difference?
  3. HRCTrev09
    Oh fark i'll just have to eat me's spinach!!!....:D
  4. stevebetts
    stevebetts Well-Known Member
    no problems with mine.
  5. Moily
    Moily Active Member
    Mine are fine too. Not got it wound right in though, so still have an inch or so's travel.
  6. slowr1der
    slowr1der Active Member
    Should even things up in the forearm dept then unless you are left handed of course ;)
  7. HRCTrev09
    Nice one i never thot of that! ;) I am right handed but i usualy use the wife's right for those occasions :D Athough i could get her to use her left hand, a wee change of scenery for her, well you know what they say " a change is as good as a rest" so tiredness is no excuse now. SWEET!!! :D
  8. kpone
    Just be careful. Her control and 'feel' will be very different with her left hand. If you enjoy it too much, her right one'll get jealous.
