Back brake reservoir help
Discussion in 'Maintenance' started by Guymx, Jul 5, 2013.
  1. Guymx
    Guymx New Member
    I'm just bleeding my back brake after fitting a braided line and noticed there is a white foam disk in the reservoir as well as the normal nissin rubber.
    I've not done a CBR before but is this meant to be there??
    Looks to me like its fell out of a bottle lid from some brake fluid!
    I may be wrong tho!
    It's the part in this pic on the right
  2. PeterT
    PeterT Active Member
    No it is a float and is suppose to be there. You can remove it if you want to.
  3. Guymx
    Guymx New Member
    Is it common to remove it then??
    Does it make a difference
