Balls sticksion
Discussion in 'Maintenance' started by Bikeboy, Jul 26, 2020.
  1. Bikeboy
    Bikeboy Active Member
    rebuild my forks awhile ago but haven't been out since I've done it for numerous reasons.
    I've bought the wife a new bike and I've been out with her.
    I've been struggling with the front end. It felt horrible. It felt hard. I could feel every bump and my arms ache.
    So today I've taken a look.
    I've got about 15-20 of sticksion.
    Ive slid the dust seals down and used some fork oil to try and reduce it. Its helped a little but still have an issue. Looks like I need to strip the forks again.
    I used honda seals and a bush kit from wemoto. Not problems when I built them.
    And used grease when i fitted the seals.
    I've still got the old bushes but I'm surprised its happening.
  2. Stuish
    Stuish Senior Member
    Annnnnnd you've lost me :D:D
  3. Bikeboy
    Sorry. 15-20mm
    I've stripped the forks this morning.and considering the oil has only been in about 200miles it was very dirty. I fitted new bushes from wemoto when I did the forks. I think they have caused it...
  4. Barstewardsquad
    I think he is talking about stiction i.e. there is excessive initial resistance to the forks moving but when they start moving they do so smoothly.
  5. SimonRR
    SimonRR God Like
  6. Stuish
  7. Bikeboy
  8. Bikeboy
    New seals from Ktech as my hinda dealer is Gash.
    Fitted the original bushes and all is right with the world again. I have forks that slide .
  9. dern
    dern Well-Known Member
    Did the bushes show any sign of wear or being bent in any way when you took them out?
  10. Kentblade
    Kentblade God Like
    Any chance you had an airlock when you rebuilt them and did not get all the oil back down through the forks, as they were so hard ?
    Always careful to make sure I pump all the oil through before refitting the top caps.
  11. Bikeboy
    No air. It was Deff the bushes.
  12. Bikeboy
    The only sign was the grey in the oil
    Nothing obvious on the bushes. But there ok now so all good.
    I fitted a later rear shock at the same time so I need to have a play with the settings.
  13. hitch
    hitch Elite Member
    Glad it’s sorted....
    I’ve got a bit of balls sticksion in this heat o_O
    • Funny Funny x 3
  14. Jez
    Jez Senior Member
    sometimes I give the stantions a polish with silicone spray before a ride, This does make a noticeable difference on bumpy roads
    I just spray a bit on a cloth then polish the forks, Keep away from the brakes
